Hey y'all I have a 2012 sportsman 400 I Snorkeled it and it does good until you go in water it will start spittin and sputtering No water in air box or carb. Any idea what it could be?
Did you water proof all you electrical connections? If you snorkels it I assume you go in deep.
If you didn't, you should spend a weekend with all the plastics off water proofing every connection. My guess is the water is shorting something out, and the plug isn't firing.
also if your exhaust was under water that could have been the problem. Too much back pressure.
