21 - 40 of 270 Posts
Looks like it is going pretty smooth. Take lots of pics as you go, this is defintely interesting.
Discussion Starter #22
Update. I now have a rolling chassis with 4 inflated tires. We used my neighbors wrecker to break the bead on the tire. We placed the rim on the ground, with a car rim of larger diameter on top of the quad rim. The wrecker has a wheel lift that can apply hydraulic down pressure. The bead was no match for the wheel lift. Next step: car wash.
Discussion Starter #23 (Edited)
Fire Duck is back from the car wash. This thing was caked with mud. I removed the front master cylinder and cleaned it up. There was some water damage inside the bore that I polished out. The water got in through the melted sight glass on the cover. The melted plastic in the reservoir was hard as a rock. I heated it with propane and teased it out with a screwdriver. I think this part is going to be salvageable. I'm a little disappointed with Polaris in that they do not sell a rebuild kit or individual parts. I need the outer boot which was melted. Also, the parts diagram shows a snap ring which was not installed on this unit. The cover for the master cylinder costs $57. What's up with that Polaris? I ordered more parts including an air box, inner clutch cover, and a gas tank. All I need to get this thing fired up is the intake boot.
Just the pictures now look worlds better than the first ones. You defintely do fast work!
Not sure what your ultimate plans are, but I have read the 2011s have weak axles and cannot handle a lift kit, so if you plan on a lift you might want to swap axles now.
Discussion Starter #26 (Edited)
I never understood why anybody in their right mind would put a lift on a quad. The lower center of gravity in my opinion is way more important than an inch or two of ground clearance. I want the lowest center of gravity possible. I guess it falls into the category of the big wheels. I want my machine to perform off road, not look like a hoopty ride. FYI the Baja 1000 started today at 9:30 AM Eastern time. Anyway, thank you for your comments. This project is coming along quite nicely. Things around here are about to get real busy once ski season starts. I want to spend as much time as possible in the shop now because in a few days my time is going to be at a premium.
On a side note: The bars are burnt up really bad. The are some pretty bad heat marks on them. My question is; Do you think the excessive heat has taken the temper out of them? Salvage or replace? Let my know your thoughts?
The bars look pretty scorched, hard to say how much damage they took from the obvious amount of heat they endured. If it were my project, I would replace them.
Nice work!! Can't wait to see what you do once you get some parts in! I vote replace too, like you said the temper may be gone and you don't want to find that out on the trail later.
Replace them! Why take the chance.
Discussion Starter #30
I'll take your advice and order new bars just to be safe. In other news, my wiring harness arrived today. It's the right one, and all of the plugs match up. the only problem: I don't know how to route it. I never seen the old one, so I have no points of reference. I know it runs up the left side frame rail. I don't know if it runs on top of the guard on the fuel pump, or does it drop down below the handle bar support plate and come through the hole by the brake switch. If anybody has any idea, or some pics of the harness routing please let me know.
What harness? I have the same machine and could take a pic.
Sent from my SCH-I510 using Tapatalk
should go up leftside,kinda split at steering stem then go to headlight pod and each side of handle bars, hope this helps
I got to be the one to ask, What did you pay for this? They should of payed you IMO lol.... jk GL. Keep us posted with pics as others stated. Very interesting
I will try to get a pic tomorrow. Just got home. Busy week for retail...
Discussion Starter #35
A pic would be nice. I'm curious to see how it routes around the handlebar support directly above the handle bar upright. They should have paid me for it? That's funny, and your a dick. I could have parted it out and made a fortune on it. The front differential is worth more than what I paid for it. Instead I decided to fix it because I need a winter project. The odometer had 250 miles on it when it burned. Structurally and mechanically this machine is in good shape. Most of the damage is cosmetic. Not to mention that I get the satisfaction of building it and improving it myself. I'm learning a ton from this project.
Cheers.
I will snap some pics tonight. As far as handle bar wires in the pod, they are routed in some split loom tubing into the pod. I believe the wires follow the left frame rail, but I can look.
When looking for machines like this from insurance companies, where do you go about finding them? What kind of prices do they put on them? Do you just get the number of an insurance company out of the phone book and call them and tell them what you are looking for?
Not sure what exactly you are talking about for the wires, but I think you mean the ones along the left rail that go into the pod.
Discussion Starter #40
That's perfect. Thank you so much. This morning I picked up my carburetor from the post office. Hopefully Fed Ex can get their act together, on Saturday I chased the truck down the road on foot frantically waving my arms until he stopped. It happens every time. More pics to follow.
