I have a friend that has a 2010 xp850 sportsman and he swamped it out last weekend while IDILING across a stream. He IMMEDIATLY shut if off, brought it home changed the oil, tilted it back to drain the water out of the exhaust, and pulled the spark plugs. He spun the starter over to blow the water out of the spark plug holes and after it spun over several times it locked up w/ the plugs out? He took it to the dealership this weekend and the mechanic said he has had several XP850 in the shop that customers had done the exact same thing to and it breaks a piston every time!!! The mechanic said you cant do these XP's like you could the other machines and simply change the oil and pull the spark plugs out and go. He even let my buddy stay in the shop w/ him and showed my buddy a chunk of the broken piston in his motor while he was there. He told him if you follow the proper procedure for "deswamping" these XP's there is no damage. (only $85.00 at the dealer to do it). My wife has a 2012 XP850 and I would like to know if anyone knows this "proper procedure" in the event the same thing happens to her's? I know one of the things he should have done is drain the runners that lead off the left side of the air box, but I dont know of anything else. I was hoping some one could shed some light on this.
Thanks.
Thanks.
