Hey fellows I am looking for a smaller type trailer to pull behind my atv. I will mostly be using it to haul camping gear into the woods and occasionally using it for hauling firewood. I really like the Polar trailer from northern tool. Anyways would like to see some of yours, or what you would recommend. I need something that will last for years to come. Post up some pics if you got them. Thanks for the help. (BTW my budget is about $500 max)
Search my name and small trailer.
I made myown works great!!
on that tight of a budget you're probably stuck with a single axle. but if you're good at scrounging, and can weld you might be able to come up with the materials needed to make a walking beam yourself. Personally I like the walking beam but there are a lot of people that use the single axles and a pleased with them.
My stepdad has a homebuilt single axle trailer. Works great for moving stuff like the sap tank and firewood for the arch.
I have one that I got at TSC. I cant remember the name of it but it works great. Has a dump feature to it and everything. Look for high ground clearance if you are going in the woods.
