1 - 11 of 11 Posts
2008 Sprotsman 500.
How do you replace it?
Dose it just go around the cover or does it have a grove that goes on the knife edge of the cover?
PVT cover what's that?????
Polaris Variable Transmission (PVT) Clutch Cover.
That's a new one!!! Were does it mention that the transmission is "PVT"?? Never heard of that before.
PVT term is from the Shop Manual of the POLARIS 2008 SPORTSMAN 500 SERVICE MANUAL.
Holy CRAP hmmm thanks for sharing!!!! Heard it called the CVT never PVT, you da man!!!!
As latebird said, it just goes in the groove of the inner cover. The sharp edge of the outer cover presses into the foam seal when installed creating a watertight seal.
Why are you replacing the seal?? Is it damaged?? Preventative maintenance?? Does it leak??
1 - 11 of 11 Posts
