I just got my clutch kit today and it come with three shim options, 1/16" or 1/8" or you can use both. Do I not use the shims or should I? If I should use the shims which one should I use?
My riding style is: i am only having fun when my tires are kicking up dirt, heavy throttle, ride trails fast and when i see a mud hole, i have to go in it. My signature below lists the upgrades i have done.
Thanks for any advice!
I have the 2011 version of your machine. I am running the heavy STI Mudtrax XL tires with the QSC kit. I am running both shims in mine. I like it a lot. I wanted something that could allow the 800 to turn the Mudtrax through peanut butter no problem
I used the thin shim, I too like to ride aggressive however I found that the thicker shim or both shims made maneuvering in tight spaces a bit of a pain, I also use my atv to plow with.
