Hey peoples,
Early 2004 Polaris 500HO. Trying to change a seal because I have hub fluid leaking from the seal at the CV boot. Just wondering the easiest way to get the CV boot out of the hub without wrecking the boot itself, making it an even bigger job.
Thanks,
Michelle
Hmm, he'll have to knock the a arm off the ball joint and remove the tie rod from the strut to swing out the strut enough to get the axle out of the strut housing in order to gain access to the seal. He'll also have to remove the brake caliper in order to be able to remove the hub.
Thanks guys. I was able to replace the seal and there is no longer a leak! Yay!
PS, Polman500, I'm a she not a he. Haha
Thanks again!
LOL....oops sorry about that Mishelly. I sometimes forget the old saying that a guy (or gal) shouldn't ASSUME anything. Glad you got it fixed.
