I have a 13 850xp and already have the QSC kit in it, but when I installed it I only put one of the shims in there and now I want both in there. So my question is I have the cover off now, can I just loosen the six bolts up and then take the center bolt out and install my other shim or do I have to take it off the machine?
Yeah, remove the center bolt then the 6 clutch cover bolts. Remove all but 2 cover bolts then with one hand squeeze the cover to the sheeve then unscrew the last 2. This pulls the cover off straight so as the bushing does not get damaged. Easier on a bench, but if you don't have a puller it can be done on the machine.
Thanks, I actually found my puller so I got it off. But thanks for the reply
