1 - 2 of 2 Posts
i have a 2012 500ho and wanted to know if the winch mount from polaris for the use of there winch would work with another 2500lb winch, i saw one at tractor supply co, and harbor freight for half the cost of a warn
you should be fine. most winches have a universal mounting pattern. If it doesn't line up it's easy to drill two more holes.
don't forget to check online. Amazon will usually have a Superwinch 2500 for about $120.
1 - 2 of 2 Posts
