1 - 20 of 27 Posts
Racing Radiator for Sportsman XP 1000 has been long time coming even before I got it home that was one thing I had on my mind . Because of my 2017 Kodiak for the start seemed to run very hot and everyone on the forums agreed and I put a temperature gauge on and it was 221f with the fan running all time so a long search I found one that said it fit an older model 2012 Grizzly but I have a 2017 Kodiak and I got one and it fit and now it running at 185f no matter what.Well the Sportsman XP 1000 is not has bad as the Kodiak was but my Sportsman XP 1000 hit a tree out of nowhere but fixed it but still had replacing it with a upgrade on my mind and so searching for a Racing Radiator seemed for a long time till I saw it on Jay-parts and I wasn't going buy it for them and The Racing Radiator was made in USA so it must be available here are so still took forever ordering it to only find it's out of stock so find a shop in Florida that had one and jumped on it. It took me 2 1/2 hours get it put in and a lot longer than if was a quick switch out but it ( 2 TIMES BIGGER) so it was not only a jammed pack fit . But all in all I got it in it's a much better,very heavy metal and Bigger Radiator and I Love it and can't wait to see how much better it is on a crazy hot summer day.
2015 Sportsman XP 1000 LE Touring
馃
Racing Radiator for Sportsman XP 1000 has been long time coming even before I got it home that was one thing I had on my mind . Because of my 2017 Kodiak for the start seemed to run very hot and everyone on the forums agreed and I put a temperature gauge on and it was 221f with the fan running all time so a long search I found one that said it fit an older model 2012 Grizzly but I have a 2017 Kodiak and I got one and it fit and now it running at 185f no matter what.Well the Sportsman XP 1000 is not has bad as the Kodiak was but my Sportsman XP 1000 hit a tree out of nowhere but fixed it but still had replacing it with a upgrade on my mind and so searching for a Racing Radiator seemed for a long time till I saw it on Jay-parts and I wasn't going buy it for them and The Racing Radiator was made in USA so it must be available here are so still took forever ordering it to only find it's out of stock so find a shop in Florida that had one and jumped on it. It took me 2 1/2 hours get it put in and a lot longer than if was a quick switch out but it ( 2 TIMES BETTER) so it was not only a jammed pack fit I must have something bent because I had to replace one of the spacers with 2 but to get it sit straight . But all in all I got it in it's a much better,very heavy metal and Bigger Radiator and I Love it and can't wait to see how much better it is on a crazy hot summer day. View attachment 149317 View attachment 149318 View attachment 149319 View attachment 149320 View attachment 149321
Nice! Did everything bolt to the stock locations and all stock connections tie in without any issues?
Sent from my iPhone using Tapatalk Pro
Yes it fits and it's for the Sportsman XP 1000 only thing I had problem with was the spacers that come with it was at least on my Sportsman was to long and push the fan back to far against my brake line so I cut them haft and put one on both sides of the rubber bushing and had to do that because the longer bolt had short threads. Look at the new pictures as I fixed them .
Only issue I had on these larger rads(thicker core) was cleaning them. Much harder to blow the shit through the core
they do work good though, had one on my grizzly 843 cc
I put one in my 800 years ago. Never showed "HOT" again!!
Reactions: crazyflyboy30
2021 sportsman xp1000 base ( stock )
I love this ! Nice .
Is this the company that makes it ?
Discussion Starter #11
It's the same but FPS Racing by SuperTarrp is what is on my box and stickers. I got mine off Ebay for $405 form a dealer in Florida and the part number is FPS11-14SCRM850 and also Look this website this is part of it.(((((((
In August 2012, SuperTrapp Industries, Inc. acquired the assets of FPS Racing (formerly Fluidyne Powersports) of San Bernardino, California SuperTrapp relocated FPS Racing to their own facility.
https://supertrapp.com/brands/fps-racing
I gotta say it, not to be mean but because it's so hard to read your posts. Crazyflyboy30, PLEASE LEARN HOW TO USE PUNCTUATION WHEN YOU POST! You have good info, but it's next to impossible to read.....
I just looked for a radiator for my 2015 xp 1000 and nothing is listed for it. I need to replace mine soon due to corrosion from being in Florida, but all I can find is OEM. I'd like a bigger radiator if possible....any sources?
Discussion Starter #14
FPS11-14SCRM850 is the part number. And I checked the OEM part number to my 2018 Sportsman XP 1000 to the 2015 Sportsman XP 1000 and the part number for the Radiator and fan are the same so it should fit like mine did on the tight side but it does fit. As for a source, I got mine on Ebay for a dealer in Florida but he not showing anything right now and I paid $405 and another seller on Ebay had it cheaper but they to are out of stock. I can also sell you my old one cheap it only has 2 pin holes that I fixed and was holding for 2 years. I did it on my second ride . Never been in mud and can show you pictures if you like.
Thanks, but I don't do used radiators, especially repaired ones. Mine isn't leaking yet, but I'm keeping an eye on it. I'll see if I can locate the one you listed...got to be one out there somewhere...New OEM are over $700!
19鈥 850SP Camo. MtAiry Maryland
Holy Crap! I had no idea they were that expensive 馃槼
Just checked, went down since the last time I looked. Showing $515 now. Mine cools fine, but I'm all about more cooling capacity....looked for that other part number, no luck so far except for one place, gonna send them a note and see if they have it...
Reactions: MrEd
OEM price shock.....someone had asked me about my 2 tone stitched seat on my SP, I looked up the cost for them via the part # on it....$465 馃槼
Discussion Starter #19
Hey I found one FPS11-14SCRM850 but it's $568 ,and you got to stroll down the
page to find it but it's there and it's said Limited stock.https://shop.goaz.com/Fluidyne-Power-Flo-Radiator-detail.htm?productid=21165064
Fyi when I was searching for aftermarket fully welded rads I used the part# not the machines model and #.
1 - 20 of 27 Posts
