I've been very skeptical about moving my radiator onto my front rack but i just spent the last few hours making the change and I'm going to suggest it to anyone that lives in more hot conditions or that like to ride mud and water... it makes a world of difference and i think my fans only kicked on one time since the change. Ive previously burnt up two fan motors cause of water and repetitive cycles of the fan running, so if anyone was wondering how well it works, its deffintaly worth the time and it only costs about 20 bucks in extended lines and hoses!
Boss Bushings screwed me and didn't send the second bushing in the front differential bearing kit. I contacted them and they completely denied that the kit was supposed to have two. I tried two different customer service people too. I even sent them a picture of their website listing that showed...
I just ordered front cv axles, bearings and seals for my 1998 Sportsman 500. Any advice on what else I should check and/or replace while I have the machine apart? I'm new at this.
TIA
I drove it about a quarter mile yesterday and noticed it was smoking a lot and it finally make a clunking noise, lost power and died. After that I couldn’t budge the pull start. Took it home and pulled off the belt cover and that was fine. Pulled off the starter cover and that was find. I was...
Sounds like my cooling fan is on its way out. Polaris fan is quite pricey, are there any alternatives out there? What is the best way to install the new fan? Thanks in advance for any help!
OK I just re-built my entire rear end - bearings, seals, etc.
The rear axle bearings are normal tapered roller bearings etc as you know.
The silly bike has a grease fitting right in the middle of the rear axle (as you know) and I am trying to understand what good that thing is.. the last thing...
