21 - 40 of 86 Posts
Well I put on the deflectors tonite. Just like I hoped they fit perfect. Don't know why they aren't on from the factory but they line up just like the 2014,plus they aren't that expensive either. The shop wired up my winch and I had to reroute the power cables to the winch a little, nothing a couple of wire ties couldn't fix.Hope this helps.
Cool, Just ordered a set for mine, 35.00 bucks shipped, from Partzilla
Side covers
fsadvar - thanks for posting info and pics. Looks like a good option for protection. The only down side I see is having access to radiator on the trail to clear mud from the fins. Last week I caked up so bad I overheated and had to splash water onto front to scrape it off. Seems like an easy removal if it needed to be done. Thanks.
If you had them, would you have to clean the Rad. Tires are the cause most
of the time. Unless your seat deep and its coming thu the grill.
Discussion starter · #26 ·
I'm glad they fit, and everyone should order and install them. I know they have protected my radiator from mud and sticks.
Aside from cost, which I hope is not the reason Polaris dropped them, maybe they felt that deleting them might deflect some of the fan air away from the engine, and reducing Rider heat problems.
I'll take the heat as I do, to save my Radiator any day!
Thanks for the followup fsadvar !
radiator covers
That's what I'm hoping. Not going that deep...I think last week was all tire spray digging out of mud. Just ordered a set from partzilla as well. If they get here in time I'll test them this weekend - one with and one without and see which one has more mud.
Delay
Just got notice that wont be shipped until friday july 24, so i dont know if they stock them, or they come from polaris, since there will be a delay.
Great find! Will be ordering mine today!
I sure hope this helps. It sure makes it a lot more closed off and makes me feel a little better. I haven't taken it out for a run but its worth the protection to me. I was telling by buds that the internet was great, let the other guy spend their money and time to see if it works. I guess I was the other guy this time.:)
You all ride safe out there!
Radiator covers
July 24? Mine says June 24, so I should have them next week. If that's the case I can live with that. Heading out this weekend so I'll have to take something to clean the radiator so I don't overheat like last time.
Other guy
I guess everybody gets to be the other guy at some point. I appreciate you doing it this time! I'll take the protection over the damage! Thanks.
Sorry, my mistake, it is june 24
What are the part numbers ? With they work an a SP? Thanks
Would you happen to know what size screws are needed? I found a set of used ones for $23 bucks shipped but it didn't come with any mounting screws.
Sorry bout the late response. I ordered the factory bolts. I will have to get the numbers. It also needs the push type pins. 3 on each panel. I just bought some generic ones. If you need the numbers for the screws I can get them for you. They are a self tapper style with a torques (sp) head.
I was assuming this came with hardware...thanks for the notice. Please send the numbers for the screws - mine should ship tmw so I'll get them ordered.
Thanks!
Thanks!
The part number is 7519092. You will need 2 of those and 6 of the plastic push in retainers. I bought some universal in a pack of 10 cause I always seem to need some somewhere. The ones on the front of the deflectors are kind of a pain to install. I just pulled the plastic bumper (?) out and wedged a screwdriver in so I had some room.
Hope this helps. Sorry for the delayed response.
Frank
Thanks!
Frank
Thanks, Frank. I'll get them ordered.
21 - 40 of 86 Posts
