I have a Polaris Predator 500 with electrical wiring altered by the former owner, I was with him in service and has all right, the problem is that it stops at random, after 15, 20 km and after the first stop stops more often, especially it stops when the lights turn on. I thought it may be due to lights, consuming too much current, but doing the same problem with the lights off, might be the spark? or maybe a relay?
I hope someone can give me good advice
Thanks :sad2:
charge battery, hook up volt meter, start and run, raise throttle a little, u should see voltage increase on meter to at least 13.5 volts, if not voltage regulator is not working.
Voltage Regulator was changed, also battery (12v 8ah) . was verified with volt meter and everything its ok. Problem happens when engine is heat and i start the lights
