1 - 1 of 1 Posts
Hi.first timer (n ireland)
Can anyone check on their machine if the rear driveshafts move if you grab them at the inboard cv joint and shake them. Something tells me they should be tight but the fronts are the same.i have just bought this machine 2015 as a none runner cat d damaged from copart. All i needed was a front fender(£22) on ebay. (Rrp £341!!!!)
Cv joint.clutch bearing.
Polaris is fairly new here so i have no others to check.
1 - 1 of 1 Posts
