I have a rattle noise on a 2014 polaris rzr 800s sounds kinda like a tensioner is bad but it dont have a timing chain on the 800s so I cant figure out what it is
post up a vid those 800s are a little noisy.
been going through this for a couple months now... check motor mounts, front driveshaft ujoints and yoke, exhaust springs and gaskets, heat shields, rear sway bar, cage mount bolts, brake pads... i still have a small rattle between 4800 and 5200 but cant find anything that is really wrong with it... also changed belt, primary and secondary springs checked weights and rear hitch... good luck.
