I'm rebuilding the rear suspension of my 02 500ho and i need the lower outer bushing. It looks like polaris discontinued it ?? What to do? :wtf:
you will have to look at after market bushings.....lots out there....there are kits on ebay also....but check around on some online stores.....some have good prices....
Discussion Starter #3 (Edited)
Its not the plastic bushings its more like a shaft/spacer that go's in the plastic bushing. polaris call's it Bushing Bearing Carrier part #5631141 find #37 on the parts list. Im dong sum research it looks like a 2002 sportsman 700 uses the same lower A arm and the same plastic bushings. My only concern is the length and the inner hole diameter for the bolt is it the same as the ones off mine?:hmmm 2002 500 ho http://www.polarispartshouse.com/oemparts/a/pol/5034f8e0f870022b94ea4b96/rear-suspension# 2002 sportsman 700http://www.polarispartshouse.com/oemparts/a/pol/5034f8e0f870022b94ea4b96/rear-suspension#
Ok i see now..bring an old one to a dealer..see if any of the newer one match up..worth a shot...a good parts guy will know...sure they been asked before
OK got the new bushings from a 2003 sportsman 500 and they will work for my 2002. :veryhappy:
