I'm dealing with 500 Scrambler..
Block of wood and hammer.
I Was having problems getting rear hub off axle.
Entire axle and hub stripped!
Guess I need both rear hubs and axle.
It's crap! Time to start looking for parts.
I'm also looking for tires...all 4.
Any reliable sites for parts?
Chicks Get Muddy Too
I would upgrade to better axles from an aftermarket such as Gorilla, Rhino or Highlifter. The hubs will have to be stock I am afraid. I have used Cheapcycles.com
I got The hub off..
Looks like about 40% of the teeth are left. I'm thinking a whole New axle would be the way to go.
You don't say what year model but the old Scramblers are bad for stripping hubs if they get any bit loose. If you can find the right year Predator hubs they are standard 4x4 lug pattern and will allow you much more options for tires and rims and will bolt right up on your axle.
