The holes on the lock an rides are the same so it should, I do know the older box does not fit on the XP if you have the rear rack extender, but I see you are going from an XP to value line, so then you should be good to go!
Thanks for the replies. When i google the box and select images it say for xp so i just wasnt sure. Its a used box as i dont need one all that often and just looking for a cheap and easy to install box.
Thanks again
