Ive been in the process of replacing my prop shaft and have got the prop shaft off, one yoke was very damaged so I buzzed it off and pulled the prop shaft from there. I replaced the U-Joints. I have since loosened all the bolts on the rear gear case and am wondering if you guys who have done this pull all the bolts out then pull the gear case back or are there certain bolts that only need to be pulled? This is for an 07 Sportsman 800.
Cheers!!
Just pull the bolts that hold the rear gearcase/diff in place and slide it back a little in order to get the prop shaft on/off.
