New guy here in Need of help... Buddy of mine basically gave me a 99 Xplorer. Lots of issues so I’ve been tackling one at a time. Got it running and runs well. Tested voltage and it was over charging. 17.5 volts at the Battery. Purchased new rectifier that says it replaces the old one. New one comes in and is a bit smaller. But essentially same size. Most Wire colors are the same but come out of the rectifier in different order. Original one has five wires. From left to Right they are. Y/R. Solid Y. Solid R Y/B. And Solid BTown. New one from left to right. solid Brown Y/R. Solid Y. Solid R anD Solid Black. So four of the five wire correspond. However they come out of the Rectifier in different order. Do I still hook them up and match wires and then just match the Black wire to the yellow brown Wire? Thanks would love some help before just hooking it up and frying something!!!
It's a single phase rectifier - the y and y/r wires are the charging coil and it makes no difference which is connected to which - red is battery, brown is ground
142202
The black wire will connect to the Yel/Brn wire and the sequence in which they enter the unit is of no concern.
Thank you very much. I’ll hook it up and see if that solves the issue. Hopefully charging drops to around 14.5 less.
Well that appears to have been the issue. Hooked it up. solid 14.56 at high rev. thanks again. Now into the next issue. Rear brake and headlights..
