I just got my predator about 2-3 months ago and i was wonndering what you do for regular maintence... And what should i do to put it away for the winter? How often am i suppossed to change the oil, and how much oil does it take? Any hep would be great thank you
What year is your Pred?They say to change the oil and filter every 10 hrs.It takes 2 quarts exactly of Amsoil or Mobile1 full synthetic.As far as winterizing,make sure your coolant is in good shape and add stabil to the gas then run it for 10-15 minutes.For regular maintenance I do this-grease all the fittings with synthetic grease after every oil change,change oil & oil filter,check your air filter and check your swing arm and bushings for movement,a-arms,ball joints,tie rods,cogs,lube the chain every time you ride and check all fuel and coolant hoses and anything else somone might add.You might put some lithium/dielectric grease on your electric connections also.
They are pretty good quads but not having a reverse gear in 03 & 04 kinda sucks,so try not to put yourself in a spot where you will need it.Pushing gets old real quick lol.
