Release Brakes
7820 Views 12 Replies 7 Participants Last post by  rws53
Brand new 2022 Sportsman 570 Trail giving release brakes message on display screen. Check engine light comes on as well. No brakes on. Goes away when you turn off the atv. Comes back which you start driving again. Dealer said this is known issue. Needs to be reprogrammed. Anyone else have this issue or heard about it.
1 - 13 of 13 Posts
Yes it's a very well-known issue. Yes they have a reflash for the computer to take care of it. Yes take it back and have it done.
Reactions: 1
2
to the forum
From the Official Forum Greeter, be careful of the other imposters.
See less See more
My dealer replaced the brake switch, and the problem was fixed. Maybe a flash is all it needs?
Yes, bought two new 450’s. They both ave the flashing “disco” screen and “release brake” message in first 10 minutes of driving….brand new vehicles.
2
Font Window Pattern Screenshot Automotive exterior
to the forum
Gas Font Automotive lighting Ball Vehicle registration plate
See less See more
Take them back to the Dealer, there is a softwere flash available to cure that problem.
2023 Sportsman 570 Trail...same error > flashing dash > release parking brake > engine check light on
with ignition on or with engine running brake lights stay on all the time but brakes are released and do not drag on the rotors
pulled the connector off brake light switch > checked continuity across the 2 pins on the switch > had continuity when it shouldn't
called dealer and they confirmed seeing lots of bad brake switches > dealer warrantied switch and 2 banjo sealing washers
I asked about a software flash and he laughed.
Reactions: 1
Yes, as I understand it, there were 2 separate problems that were covered under warranty. One was the ECM programming reflash. And the other was faulty brake switches. I believe all of the ‘23 models had the correct ECM programming but suffered from the faulty switch.
2
Font Line Window Pattern Screenshot
to the forum
Ball Gas Font Vehicle registration plate Automotive lighting
See less See more
Does it hurt to drive them while you wait for the dealer to do the warranty work?
If it were mine, I would be driving it until it got repaired.
Reactions: 1
if you are experiencing a flashing dash > release parking brake > engine check light on I would just unplug the brake light switch to cancel the annoying distractions till you can get it fixed
Reactions: 1
1 - 13 of 13 Posts
