The big news is here: we've released the 32.5" Outlaw 2! You can check out the product online here:
http://www.highlifter.com/p-4410-outlaw-2-325x105x14.aspx
Here's the scoop:
• True-to-size 32.5x10.5x14
• 7-pitch design
• Weight: Appx. 56 lbs
• It’s tread depths range from 1 5/8” in the center to 2 3/8” at the shoulder and 1 1/8” on the side wrap.
• Scooped treads to maximize pulling, digging, paddling through deep mud & water
• Wider lugs to increase surface contact
• $240.00
Check out our comparison video where we ran the same PSI in two competitor tires. Our 32.5" actually measured bigger than the 34" tire!
Here's the scoop:
• 7-pitch design
• $240.00
