Sure Keith! Remove R.H. Footwell..remove R.H. Flywheel cover or "recoil" cover, I've also found it makes it easier to remove the two bolts holding the rear master cylinder on so you can depress the brake lever enough to remove the bottom bolt on the cover. Once cover is off, remove flywheel and bendix pulls right out! Be careful not to lose the washer on backside of bendix where it fits into case.
