I am about to remove rear axle and strip down rear gearbox on a shaft driven 2001 325 magnum/ xpedition.
I have looked at exploded view and rear of bike, Am thinking that will need to remove right hand wheel hub a circlip next to gbox seal and pull axle out from LH side. i am struggling to understand how the crown gear is attached to the axle so am thinking I will need to open gearbox as well and maybe remove a key from axle. has anyone been through this process before?
I am hoping to clean out check gbox and replace leaking seals
any comments would be greatly appreciated.
thanks for your help in advance
