I have a 99 xplorer 300. I have a new starter and bendix on hand and have a few questions.
1. To remove the pull cord plate cover, it looks like one of the bolts in lowest left corn is behind a frame plate. I am thinking a 10mm wrench from the bottom is the only way to get to it. Is that correct?
2. I took the bottom skid plate off and think I see the starter. Is that where it is on 1999 xplorer 300?
3. If it is under the bottom, any advice on it's removal?
Thanks,
Mike
1: just remove all 10mm bolts.
2: yes
3: remove the two 10mm bracket bolts and then there are two bolts when you remove recoil starter housing. Those two bolts secure the bendix
