1 - 10 of 10 Posts
I’m upgrading my Sportsman 850 with a CECCO front pinion cover.
Spent some time at YouTube U and the install seems straightforward.
However, I haven’t had any luck punching out the prop shaft yoke pin. I sprayed Rust Blaster liberally and tapped with a dowel punch, and a center punch. It doesn’t budge, unlike in the vids where people just pop it right out after a few taps.
Any tricks I’m not aware of? One side better to punch than the other? Special tools
Anxious to get it done and go riding.
2017 Sportsman 850SP
Palm nailer
Air hammer
Reactions: pcaster
It won't "tap" out. Use a BIG hammer and the appropriate sized drift punch and hit like you mean it.
Replace the roll pin with a 5/16" x 2 1/2" grade 8 bolt and lock nut to put it back together. Way better than beating on the pinion bearings and seals to get it apart next time IMO.
Discussion Starter · #6 · (Edited)
Okay I’ll wail away on it. Just didn’t want to inadvertently break something.
Correct that I can punch it out from either end. I don’t see any head or other one-way out.
Also like the hardened bolt to button it back up. Makes sense.
Either way, use a air hammer, as it won't put stress on the bearing or case from using a BFH!
Discussion Starter · #10 ·
Happy to report a hybrid of air hammer and banging a dowel punch got it done.
The air hammer got it started but soon the tapered-end chisel started binding as it drove down the center of the pin.
After that I used a mallet and tapped it almost out. Used a 5/16” bolt to pop it out.
All in all, a bit tedious but doing a little at a time it wasn’t enough to avoid doing the upgrade yourself.
The vexing pin
1 - 10 of 10 Posts
