1 - 20 of 20 Posts
Going to replace the rear wheel bearings in my 98 Sportsman 500 today.
I hope replacing them goes pretty smooth.Most likely getting the old ones out will be the hardest part as usual im thinking.
Anyone remember what auto parts store bearings work?
I think i remember reading about some car bearings out of a Kia will work or something.
Discussion Starter · #2 ·
Found this after using google for awhile off this site..
Alternative Polaris Sportsman Rear bearing list
thought this list might be useful. got it from this site: 510003 Auto Wheel Bearing 40x74x40:Sealed:Ball Bearings
510003 auto Wheel double row Bearing, here are the dimensions of the 510003, the 510003 inner diameter is 40mm, the 510003 outer diameter is 74mm, 510003 width is 40mm.
•Item: 510003 Double Sealed Ball Bearings
•Dimensions: 40*74*40 mm/Metric
•ID (inner diameter)/Bore=40mm
•OD (outer diameter D1)=74mm
•Width/Height/thickness=40mm
•510003 Closures: Double Sealed with rubber seals
•510003 Type: Wheel Ball Bearings
•Size: 40mm x 74mm x 40mm
•Quantity: One Bearing 510003
Fits the following Vehicles
•2006-2000 AUDI TT
•2006-2000 AUDI TT QUATTRO
•2001-1994 KIA SEPHIA
•2004-2001 KIA SPECTRA
•1995-1990 MAZDA 323
•2005-1990 MAZDA MAATA
•1996-1992 MAZDA MX-3
•2003-1990 VOLKSWAGEN PROTÉGÉ
•2008-1998 VOLKSWAGEN BEETLE
•2006-1995 VOLKSWAGEN GOLF
•2009-2006 VOLKSWAGEN GTI
•2005-1999 VOLKSWAGEN JETTA
•2009-2006 VOLKSWAGEN RABBIT
now to the auto parts store
Let me know how this project goes, and if these are the right bearings. I have 2 units that will need this job eventually.
These bearings were great but the only downfall is that they're 53 dollars a piece
Try a bearing store.for a better price.
Use a cheaper brand bearing. Use a Carquest #B510003 about $21.00 each at the Carquest i work at.
Sorry I didn't see this post earlier.
You can also buy u-joints,belt, and front wheel bearings at parts stores.
Discussion Starter · #9 ·
damn sux to be me..over paying for bearings:disappointed:
I realize this is kind of an old thread. Didn't wanna start a whole new one. I will be doing rears on my 2012 800. Any tips or tricks to the job? Looks pretty straight forward.
Do not beat on the bearings, EVER. Use a press and warm the nuckle just enough where you cant touch it. Do NOT get it cherry red.
Do not use Polaris bearings. Id use SKF or Timken. I just ordered a Timken from amazon here Timken 510003 Wheel Bearing : Amazon.com : Automotive
Do not over torque your axle nut and do not use an impact to tighten it. Use a torque wrench.
While you have the nuckle off its a good time to pop the rear axles out and pack the splines with antiseize. They rust pretty badly on Polaris machines and can make axle removal impossible in the future.
Thanks Thomasj. I got some bearings off ebay for 19$. Free return, so we will see.
Discussion Starter · #17 · (Edited)
Come on mods. ..Don't we think this thread is Sticky worthy?
Lets make this a sticky.
Thomas j i would like to know the part number aswell.
Btw nice way to bring back a old useful thread.
The Timken bearing I ordered was made by NSK. They are the bearing supplier for honda automobiles and yamaha ATVs. Just so you know in a few hundred miles where to get a good bearing :cowboy:
I will inspect it when I get it for sure, if I think it is inferior it will go back. Mine is not shot yet, but on its way.
Same part # I got off eBay for an NMD bearing.
Sent from my MB886 using Tapatalk
1 - 20 of 20 Posts
