Same issue as other posts, 4wd not working in reverse. Changed diff oil, was dark , replaced with Amsoil diff oil. No change, all works as it did, indication " slow" four wheel symbol appears when over ride button is engaged. AWD works in high/low forward all tire spin.
Traced the wires from differential to the connector , took apart tested wires from AWD switch , 12 volts on grey wire when turned on, nothing on br/wh with no reference to ground. Is this wire a ground?
