has anyone ever had the reverse light stay on even though its in neutral or any other gear? Im in the process of changing the starter and wanted to know if the reverse light staying on would keep the ATV from starting even though its technically in N? I'm assuming there is a switch in the shifter that tells the light indicator its actually in N and if so is there a fix or bypass for this? Thanks again for all the help on my other post.
Discussion Starter · #2 ·
also even though the reverse light is lit it am getting 12 volt from the start button to the ignition solenoid and the solenoid is engaging. So maybe the light being lit isn't a big deal, who know.
Discussion Starter · #4 ·
probably is a short somewhere. as long as it doesn't effect the machine im fine with it staying on reverse light.
