1 - 8 of 8 Posts
Hi, I have a 04 sportsman 600 twin. I don't use reverse much for any distance. This year I put a plow on and when I plowed for the first time i notice that after about 20 feet of reverse, the machine spits and sputters. Forward it runs like a new machine. This is after it's completely warmed up too. Any ideas?
Yeah a friend just told me the same thing after I posted. I didn't use override because I wanted to back down the driveway a bit faster and the dash always says "slow" when I hit the override.
It reads "SLOW" only as a cautionary / safety means to cover Popo's back side and remind you not to get carried away in reverse..... the Yellow override will also allow AWD to work in reverse, along with removing the reve limiter (sputtering).
Without the reverse limiter it will go just as fast in reverse as it will ahead. Makes it kind of hard for some to steer.
1 - 8 of 8 Posts
