Small 110 atv wont start after i accidently reversed jumper cables directly on the battery wires...since we have never possessed a battery that can provide enough amps to get it to turnover. i replaced the cdi, solenoid, and stator. The old stator was visually damaged.
Im going to get my proximity tester and see if the key switch wires and the starter/lights button wires are getting any current. i will update in an hour.
First off... Hello & Welcome :wave:
Did you start with the simple/cheap fix first...... the fuse's?! :dunno:
Yes I checked the 10a 250v glass fuse...the filament was broken. I replaced it. I didnt see anymore fuses. Could you tell me where the other fuses are located?
What machine.... "Small 110cc atv" doesn't cut it!?
On my son's Tao Tao, I think they are near the rear of the machine or under the seat..... :dunno:
ATA-110H TAOTAO...i replaced the fuse under the seat-it was located in a fuse holder in-line with the red wires 10 gauge wire.
