1 - 2 of 2 Posts
Finally got my preddy timed and now clutch orr gears slipping wont hardly move just curious wT im gonna have to do to fix. 2004 troy lee.
If the gears are slipping it will require a complete engine disassembly to repair, but gears typically slip (jump) in just one or two gears while all the rest are fine, so I will presume it's a clutch issue. first determine if it's the clutch or cable - cables can bind and hold the clutch in release - inspect the cable, if the inner wire can be moved in and out of the sheath with the force of pushing a straw into a Steak and Shake milkshake, then it's not the cable - if you have to push or pull the inner wire really hard from each end to get it move it might be the cable - if you have to use pliers to pull the wire through the sheath, the cable might be the only problem, but if you have been running with a bad cable, the clutch is probably toast. If you replace the clutch, get the friction plates, driven plates, springs, oil oil filter, engine cover gasket and a new clutch cable (I never replace a multi plate wet clutch without replacing the cable). If you are experienced, allow an hour to do the job - if inexperienced, get a manual and read it first - allow about 2 hours to include inspections and measurements as the work progresses and refer to the manual as necessary for proper assembly and tightening.
1 - 2 of 2 Posts
