I am looking to get a set of 28" zillas for my '13 800efi. My question is 12" or 14" wheels? I am leaning toward 12s to keep weight as low as possible, and so I can run a ITP delta steel wheel to save quite a bit on cost. For 12" wheels I will probably run 28x10 tire all around?? With 14s - 28x9 front and 28x11 rear.
Im running the 14s with 28/9.5 and 28/11 combo.
Do you know if the Zillas are going to run small? If the do not I might go with a 27, but if they do I am going to go with the 28's. I want something reliable. I don't want to have to worry about popping axles all the time. Think 27s vs 28s will make much difference with them being so light anyway?
Zillas run an inch smaller than they say. i.e 28s will measure 27 inches
Btw the 27s compared to 28s r the same weight bc the 27s run wider 10 and 12 compared to 9 and 11 for 14 inch rims anyway
