Hello there. So my first issue started here: Melted voltage regulator plug/wires.
I went through and found the weather pack connectors to repair my main harness. Installed that, and I thought I had swapped a wire or 2 when doing so. I did a continuity test from the stator plug to the harness plug I fixed, all check out, so I know it's not something I did.
Now I have a new issue. I purchased a new Mosfet Voltage Regulator Rectifier from RMStator. It is as described Plug and Play, everything hooks up.
However, when I start the machine, the idle RPM's are fine, but after a few seconds the RPM's drop. Normally around 1170 but drops anywhere between 600-900, but there is no physical noise change in RPM's. If I give it throttle they drop more.
Is it possible that it was wired wrong from the factory? I don't want to run it too long to try and trouble shoot as I don't want to fry anything.
I swapped out the OEM regulator I have as a backup into it's spot and RPM's are perfect, changes with throttle doesn't drop at all.
Anybody have any ideas? Suggestions? Don't really want to send it back if I can just swap a wire in the plug and be good to go.
Thank You.
Thank You.
