Hi all, I recently rolled my XP and am now in the process of fixing it. One of the things I need to get is the front rack (PN: 5436865-070) which is $94.29 at polarispartshouse.com. I am considering getting the front cargo box kit (PN: 2876600) which is $139.39.
My question is, does the cargo box kit totally replace the front rack? If so, I only need to purchase the cargo box kit, right?
Oh, in case you were wondering how I rolled it. I was at Cole Creek two weeks ago and came upon several small (30-40ft) hill climbes. I decided to try them and took the first with no problem however I had to lean over the front quite a bit. I decided to take another that looked a little steeper and about 3/4ths of the way up it had a little bump making it even steeper. Once I hit that my front tires came off the ground (me still leaning over the front as much as possible) and flipped over top of me coming down the hill. The front rack, seat, and rear cargo box all got ripped off in the process and the front end got all bent out of shape. I was a bit banged up but was ok enough to pull the front fender out to stop it from rubbing on the front tire and do a few other minor repairs in order to drive it out of there. Took about an hour to get back to the parking lot riding on mostly gravel trails.
The next day my ribs heart bad and I had aches and pains all over. I didn't go to a doctor but I suspect I bruised or cracked a rib (or two). I'm still hurting but well enough to start fixing my wheeler.
