1 - 14 of 14 Posts
i know bigirard fits two packs in his lock n ride if he doesn't chime in IM him.
Not in the front lock and ride. Only 2 one gallon rotopaxs. You will also have to replace the lock and ride hardware with a solid bolt or the tanks won't fit. The lock and ride lever lock handle will be in the way. Easy fix as you can buy a bolt at hardware store. But you will have to use two wrenches to remove and install the lock and ride cargo box, no longer a lock and ride but who cares? Never take it off anyway unless doing maintenance.
that would be a no go for me, I think. when away for days on a ride I have to take the front box off to get the hose in to wash the rad and I avoid the mud. I have also been on longer day rides where I needed access to the rad to do a quick wash.
this is how I mounted mine up. I can go up in size or stack them.
Discussion Starter · #9 ·
Yeah I have the touring model and im going to be putting on the rap around storage on the two up seat so im trying to find out how to carry extra fuel as well
Sent from my SCH-R530U using Tapatalk
how much fuel do u want to carry? I know a couple of members bolt cans on the left and right side of their front storage. or do the two 1 gal cans inside the front lock n ride.
like kemblkr stated u have to use bolts instead of the lock n ride latches and ur good to go.
mounted mine on the rear bumper using the RZR plate.
1 - 14 of 14 Posts
