Hi guys
I fixed all problems I hope
But notice today that some times when I’m driving rpm show 0
Any ideas stator crank sensor new and new stator with fly wheel new pump
What are we working on???
I would check the connections at the instrument cluster and ECU. Make sure there is no corrosion or loose connections. Other then that the crank sensor should ohm at 560.
What do you mean at 560 ?
At least can I drive like this to do one small trip ?
