Rubber Bushings
1397 Views 5 Replies 4 Participants Last post by  Daishi
My stepson was a little eager to get the plow off the Sportsman the other day. Since he didn't know how to remove it with the unlocking handle, he pulled the clovis pins that hold the Plow Mount (#2881424)and the Plow frame (#2879630) together. Got himself a nasty cut for his efforts. Naturally, I wasn't pleased by this and watched a video to make sure I put it back together correctly. I had the clovis pins and the cotter pins, but the rubber bushings were missing (if they were even there in the first place). Searched the area to no avail. Does anyone have an idea where I could purchase a set online? Looking around, I can't find part numbers that would make it easier to make an order.
J/K around with ya
Clovis: The Clovis culture is a prehistoric Paleoamerican culture, named for distinct stone tools found in close association with Pleistocene fauna at Blackwater Locality No. 1 near Clovis, New Mexico, in the 1920s and 1930s.
Clevis pin: (plural clevis pins) Part of clevis fastener that allows rotation of the connected parts about the axis of the pin. A clevis pin consists of a head, shank and hole. The hole passes through the shank at the opposite end of the pin from the head.
Reactions: 1
I was itching to correct the misnomer, but resisted and I know nothing about the rubber bushings - I have only installed 3 plows and only one on a Polaris - all were Warn plow set-ups and none had rubber bushings.
I just like to tease folks hoping though they don't get ticked off by it.
  • Haha
Reactions: 1
If you are talking about the black plastic spacer I’m pointing to, use a garden hose sealing washer as seen on left (red washer) to replace it.
Bicycle tire Tire Wheel Automotive tire Bicycle wheel
See less See more
Reactions: 2
Thank you.
Reactions: 1
