I am looking at buying 30 inch black mamba on HD3 offset rims and I need to know if they will fit on my 2013 sportsman 800 without changing lugs ... Etc
Welcome to the board!:med:
I don't think they will fit on the front without spacers because of offset, and the wheel studs you have no are likely too short, you'll need longer studs, and the stock lugs you have now will not work, you'll need acorn type lugs for alum wheels.
Shouldnt be a problem at all, I had aftermarket 4+3 offset wheels with OL2s on my 800 when it comes to the studs, but yeah prob need spacers in front as my OLs were 9.5" wide and were about a half inch from the strut. And make sure you get the SAE lug nuts not metric, xp and value models have different studs.
