I asked in the Xplorer forum but nobody seems to know. I have a 98 Xplorer 400 4x4 and wondering if the frame is the same as the Sportsman of the same era? They sure look the same. Looking for a center plow mount plate and Warn lists one for Sportsman going back to 96 but nothing for Xplorer.
What is your VIN?
A 98 Xplorer 400 is a two stroke with chain drive and a swingarm rear suspension. The frame is not even similar to a Sportsman.
A 97 Xplorer 500 however, is virtually identical to a Sportsman 500. They share the same four stroke engine, frame, suspension and all. I think the only real difference between the two is the plastics.
If this helps. I used to have a expedition and I used the same plow mount for it to my '03 sportsman 500. The plow mount mounted under the foot pegs. I do remember that underneath-wise, everything from the pegs forward everything looked the same.
polman500, I'm well aware of what the difference is in engine and suspension, but why would the frame - or at least the part underneath where you would install a plow plate - be different? They're certainly the same physical size. I'd be surprised if they didn't utilize as much in common as they could for cost saving.
That's what I was thinking
Oh well, now they may be similar enough for the plow mount to work. Only a test fit would tell you that. I thought you were asking if the frames were the same... They are not.
Hey, no prob. Yeah, I guess I assumed in my first post I was only needing to know about the underneath where the mount would go. I tried looking on Polaris parts to see if the skid plates were the same, but I don't even see a skid plate for the Sportsman.
I suspect that even if the plate wasn't an exact fit, it would be close enough to make it work if it just needed some different holes drilled. I know from the Warn site that newer Sportsman takes the same plate but needs some different holes drilled.
