I'm not sure where the starter relay is located or how to check to see if the starter or the relay is bad. I don't want to take it to the local dealer who charges an are and a leg just to check it out.
Don't know what the symptoms are, but I've had moisture problems in a starter which can cause a brush to stick, and it just clicks when you push the starter button.
start with your battery [ good n fully charged ] ?
