The little "wrench icon" on my dahs flashes upon start up, I know this is a scheduled maintenance/service interval timer of some sort. I don't have my manual anymore, what exactly should be done? My 2013 Polaris 400 Sportsman only has 62 Hours/485 Miles. Any suggestions? Thanks!
Time for some maintenance. Engine oil/fiter drain/fill, air filter (mostly check and tap Lightly/gently to remove the loose stuff), grease any fittings and reset the maint lite (not sure how exactly but someone will chime in soon).
Most on here use either the Polo brand of oil/filter or go with some brand you trust But must be Full Synthetic in the 0-40, 5-40, 5-50 range (depending on how hot it gets there). Many here use Mobil-1, Shell's Rotella, etc. and many use Wix, Purolator but not fram filters (poor construction?). Many here also use synthetic grease and/or water proof versions (marine) if they dunk their quads alot or mud them. Look thru the maintenance/oil change section lots of good info there: http://www.polarisatvforums.com/forums/atv-oil-lubrication-filter/ and the Repair/Maintenance Section too: http://www.polarisatvforums.com/forums/atv-repair-maintenance/
Luck!
OEM oil and filter
^^^^What they said!!!^^^^^^^
