The all-new Scrambler XP® 1000 EPS is the new king of big-bore sport ATVs, featuring industry-leading 89 HP and the most responsive power that the ATV world has ever seen. It also features all-new dual exhaust and electronic power steering (EPS) to give you ultimate sport performance.
pls stot theling the scrambler 1000 is good....its a big garbage atv...with a big garbage suport frome polaris...woth a verii big price ..
i buy this machine 5 mownts ago.... in 5 mownts i have 3 veri big problems ....each problem whos 1 mownth to recive unser frome polaris support. so in 5 mownts atv whos good just 2 mownts...
now i expline...first ride first dai grup problem ...all front grup down......1 mownth to fix.....after fix, sec round the cooler broke big broke .1 mownth to fix..veri shet support ...never unser...and never find pices ... and im not making extrem sport...everi time after 20 min i goo home ...becose scrambler down...pls for all..BAD QUALITI PRODUCT ...NEVER BUY SCRAMBLER 1000 ... IS A BIG BIG GARBAGE .... SEE THIS PICTURES PLS.... 0 km polaris ...sori for mi english ...hopo yyou understand ....
I plan on buying a new scrambler 850 in a couple months and id like to know all the common problems before I buy. How good on gas is it? How does it stack up against the renegade 800. Can it keep up to the 1000's without much trouble?
-Thanks
Well I’m in the process of getting my brothers highlifter out of the garage so I can start on my other brothers 2018 scrambler 1000. I ordered the frame braces front and rear and also the differential brace and front diff cover. This one will probably get a snorkel, 4” portals and 33” tires with...
After months of rough pulsing idle with no real solution it is safe to say I have solved my issue and possibly yours. I have replaced plugs with ngk iridiums. Cleaned and even bi passed my throttle stuck sensor. Adjusted throttle cable and cleaned and disasembled. Clean existing tmap and ordered...
Ok so I just bought this last week and brought it home. Started fine when I got it home and parked in my garage. It’s stored in garage in 60+ degree weather. The gauge cluster turns on and no warning lights. The headlights work fine and don’t flicker when trying to start. Battery voltage is at...
Anybody broke the plastic seat tabs off their seat? The longer ones that hold the back of the seat and secure it to the frame? I broke mine at last weekends race, both of them clean off. I held the seat down with my legs/knees and finished the race.
I have a solution to fix the tabs with 1/4"...
