just removed my carb to have it cleaned and rebuilt, and I'm curious what this knob is that has like a flat head screw driver tip on it, is this something I should check out since its apart ?
That is your counter balancer oil dipstick.
It requires 3.5oz of oil, do not over fill or it will smoke like a bastard. Also the seals on these motor's dry out so if you see milky colored oil in there when you drain it, chances are you will have to do crank and water pump seals. The drain is located on the front of the motor. You can find the seals on ebay for $15.
