1 - 2 of 2 Posts
I swapped my OEM rear hubs for 2008 Predator 500 rear hubs. The wheels and tires are off a 2013 RZR 800 4x4. I had to mount the rear wheels with the valve stems to the inside. Because of the wheel offset. There is plenty of clearance between the rear tires and wheel wells. I also had to remove the washers from the rear axle so the axle nut of wheels would fit allowing cotter pin to fit through cotter pin hole of rear axle. I am happy with the way it turned out. I will be getting a 42 tooth rear sprocket to help compensate for the larger tire size.
i have the same idea
i heard that only 2003 predator will fit a scambler,Though i have a 99 model,maybe the axel is different
1 - 2 of 2 Posts
