Welcome to the board.
First make sure the lug nuts are all tight. If that's not it could be ur wheel bearings. But hard to believe they r out already. They usually last 1000 miles
Wait...so you hit a dip so hard you blew the tires off the rims, got a concussion and broke a rib...now you want to know if play in the tires is "normal"? I would usually say its not normal, but considering you wrecked the quad I'm going with it being normal for the situation you put it in.
Sounds like you need to be supervised when you are on a quad. Second choice maybe you should not have a quad..
