I would really appreciate some help on how to remove the water pump shaft from the static cover. I can’t find any Info online and I do not have a service manual handy. Thanks in advance
155021
155022
You use a suitable sized pipe section to support the inner part of the housing around the shaft and a socket or something similar of the appropriate size as an arbor to press the shaft out toward the inside of the case.
Ok thanks for the reply. I downloaded a manual and did read that.
