I have a 2002 Polaris scrambler 90 that has no spark. It lost spark a few months ago after I shut it off to take a short break after riding for a while and about an hour later when I tried to start it again, it would not start. It always started in the first kick so this was a bit of a surprise to me. I made sure it was getting gas to the carb and tried to start it again. After trying to kick start it for a few minutes it eventually started to puff and after a bit more kicking it finally started. I rode it around for about 15 minutes and everything was working perfectly. I shut it off with the key and took a break. After an hour i wanted to ride it again and it fired right up in the first kick as it usually did. After only 5 minutes of riding, it died abruptly and would not start back up. This is when I found that it had no spark. I tried a new spark plug and still nothing. I disconnected the black/white kill wire from the C.D.I to bypass all safety switches, nothing. The Ignition coil tested within spec and I even cut a little bit off the end of the spark plug wire and got a new spark plug boot, still nothing. I cleaned a few connections and made sure they were all good, which they were, still no spark. I tested the ohms of the stator and found that the stator was not within spec. The manual said the resistance of black to white/red should be 450 ohms but in my tests black to white/red had only 110 ohms. I bought a cheap aftermarket stator on eBay and replaced the old one with it but still no spark. I also noticed that if the engine is cranking and I hit the kill switch or key switch while it's cranking it will have one strong spark at the plug and no more. If I put the plug in the engine and do the same thing it will pop once. It does the same with the old stator as well. I am thinking that it must be the c.d.i that is faulty but I'm not sure because the stator was not within spec before I replaced it. Just to be sure that I didn't receive a faulty stator I tested the new one and it was perfectly within spec. I am about to buy a new c.d.i but they are very expensive and I want to be sure that it is the c.d.I that needs to be replaced before I buy one. Any help or advice would be greatly appreciated.
