Engine Turns Over But Fails to Start
No fuel
Dirt in fuel line or filter
Fuel will not pass through fuel valve
Fuel pump inoperative/restricted
Tank vent plugged
Carb starter circuit
Engine flooded
Low compression (high cylinder leakage)
No spark (Spark plug fouled)
IGNITION SYSTEM TROUBLESHOOTING
No Spark, Weak or Intermittent Spark
Spark plug gap incorrect
Fouled spark plug
Faulty spark plug cap or poor connection to high tension lead
Related wiring loose, disconnected, shorted, or corroded
Engine Stop switch or ignition switch faulty
ETC switch misadjusted or faulty
Terminal board or connections wet, corroded
Poor ignition coil ground (e.g. coil mount loose or corroded)
Faulty stator (measure resistance of all ignition related windings)
Incorrect wiring (inspect color coding in connectors etc)
Faulty ignition coil winding (measure resistance of primary and secondary)
Worn magneto (RH) end Crankshaft bearings
Sheared flywheel key
Flywheel loose or damaged
Excessive crankshaft runout on magneto (RH) end - should not exceed .0024″
Faulty CDI module
